Author Topic: Dynaudio  (Read 50830 times)
Offline jivemonkey
Re: Dynaudio
« Reply #100 on: 23 January 2014, 19:29 »
Hi,
I have adjusted mine to bass +3 and the sub on max.  It seems to be better but still not quite as good as the mk6.
Ian
Are there controls on the actual subwoofer in the boot, that let you adjust it's bass output independent to the bass settings then?
Nope, there's an independent sub level (I think it goes from -5 to +5) in the sound menu.
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline Peeair
Re: Dynaudio
« Reply #101 on: 23 January 2014, 19:37 »
Hi,
Ian
That's interesting, I haven't seen that. I thought there was just the Bass, Mid and Treble settings?
I'll have a look tomorrow.
Golf GTI MK 7, Manual, 3 Door, Pure White, Performance Pack, ACC, Keyless, Dynaudio
Offline AlanH
Re: Dynaudio
« Reply #102 on: 23 January 2014, 19:38 »
Last item in the main Sound menu page.
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline Brenbo
Re: Dynaudio
« Reply #103 on: 24 January 2014, 10:04 »
I can also confirm there is a separate subwoofer slider as described at the bottom of the sound menu.
Offline AlanH
Re: Dynaudio
« Reply #104 on: 24 January 2014, 17:27 »
I had a closer look at my Dynaudio setup today. After playing with the settings for a while I noticed that the Individual EQ settings you enter are not instead of the Profiles (Dynamic, Authentic etc,) but as well as.  For example,  If the individual EQ settings are set to flat Bass 0, Mid 0 Treble 0 (default).  All Profiles sound as they should.  But if I set the EQ settings to unique values other than 0 the Profiles all sound as if they are adjusted.  Is this correct?
Am I to think of the Individual EQ settings as a way of fine tuning the existing Profiles supplied :huh:
I had a play today. Went into Profiles and selected Authentic, then switched to Individual, where Bass, Mid and High were all set at 0. Adjusting those EQ settings did have an effect on the sound quality, but I'm still not sure if I'm tweaking the Authentic profile, or or creating a new Individual setting. I need to read the Dynaudio manual again.
Offline iandjm
Re: Dynaudio
« Reply #105 on: 25 January 2014, 18:14 »
Hi. Does anyone know where the Dynaudio amp is? It was under the passenger seat on the mk6 but there's not enough room on the mk7 under seat.
Ian
2017 MY Golf R 3dr DSG | Lapiz Blue | Dynaudio | Heated Screen | Advanced Phone | Sat Nav | Winter Pack
Offline cbx750p
Re: Dynaudio
« Reply #106 on: 20 July 2014, 04:44 »
Hello !
found this thread and seems it have been quiet for months.  :sad:
I am trying to retrofit the Dynaudio on the Golf Mark 7.  Can someone help me with a complete scan of his/her Golf 7 originally fitted with the Dynaudio ?   :smiley:
Thank you so very much !
Jimmy
« Last Edit: 20 July 2014, 05:12 by cbx750p »
Offline p3asa
Re: Dynaudio
« Reply #107 on: 20 July 2014, 09:42 »
Ian
There is certainly something under there with a plastic lid covering it.
Offline Ginge 35Edition
Re: Dynaudio
« Reply #108 on: 20 July 2014, 20:10 »
Bro has it in his and it's definitely better than my Edi was. Gutted the R can't be specked with it.
Offline Booth11
Re: Dynaudio
« Reply #109 on: 20 July 2014, 23:21 »
You're not the only one that'll be gutted  :sad:
Ginge, have you been told Dynaudio is never likely to be available on the R then?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
