Author Topic: Very Strange Issue With My 1.8 T  (Read 7681 times)
Offline Female_Golfer
Re: Very Strange Issue With My 1.8 T
« Reply #40 on: 09 April 2013, 20:04 »
The car behaved a little differently tonight. When it got warm, between 90 and 130 it felt sluggish and lacking in power. The fan actually came on tonight, I hadn't noticed that on before.
« Reply #41 on: 09 April 2013, 20:08 »
That's 90 and 130 on the temp gauge not the speedo. Lol
Offline topher
  • Administrator
  • fully functioning
« Reply #42 on: 09 April 2013, 20:10 »
i'd avoid driving it until you get it sorted, you don't want to cook it.
Offline Nino
« Reply #43 on: 09 April 2013, 22:33 »
When I first got my GTI my car was doing the exact same as you althou my power was ok. I didnt notice however that my MPG was bad as in lower than what i get now, I was lucky to hit the early 20's on the MPG mark. I changed my Temp sensor & termo (was a fatherless son to change the thermo) both for gen parts then I cleared my codes and my car got to 90 and stayed there, I also noticed my MPG got alot better about 27 around city and 34 on B roads & late 30's early 40's on motorway this was about a month after owning my car which strangely enough had a new cam belt & water pump fitted before I got it I later found out that they over tightend my engine mount bolts and 4 months later they snapped in my block costing me a good £700 to have the old bolts drilled out and new mount supplyed.
If i was you, I would book your car into VW, have your Cam belt, Water pump and tenioners & I would also request your thermo to be changed along with a GEN Temp sensor & request your engine mount bolts to be changed.
By VW doing it and not a VW specialist you will have a 2 year warranty with VW, if you engine breaks they will do a full rebuild for FREE! a specialist would prob source a 2nd hand engine and replace. (could be wrong thou)
I recon it will cost you, about £450 max for all the work and you will have a nice VW stamp in the book, you may as well get them to do a full service while they are at it. at least then your car should be runnig 100% and you wont be a debt with a mk5. ;)
Hell if for some unknown reason your car should by some unknown reason to the whole human race still have that problem, *cough* VW Warrenty*Cough* "it was running fine until it came in for a service and cambelt change" :wink:
Other than that if you wanted to try your hands at a thermo change, follow the link below, the only hard part is getting to the top bolt, you can easly round off the bolt so make sue you got a correct tool you will think that by removing the alterator would make it easyer, truth is, it will be it CAN be done if you take your time :)
http://www.golfgtiforum.co.uk/index.php?topic=101783.0
« Last Edit: 09 April 2013, 22:39 by Nino »
Current - MK6 GTi Edition 35
« Reply #44 on: 10 April 2013, 08:08 »
Thanks for that reply Nino, really appreciate it.
I noticed just this morning that the mpg was/is shocking, I bet it's around the 20mpg mark. Normally I'd see early 30's without trying.
I'll have a think about it today, I could get the work done like you have said and then keep the car for another year or so.
Offline Nino
« Reply #45 on: 10 April 2013, 11:36 »
That will defo 100% be your non-gen temp sensor causing that.
Offline kuvalee
  • Approved vag painter since 1999
« Reply #46 on: 18 May 2013, 18:39 »
Hello, I live in huddersfield and work at Huddersfield Vw so I know all the mechanics some who do work on the side. If you want some one to have a look at it I can give you there number?
I also know the owners of vas tech on Manchester road and ivs Vw specialists on Manchester road both are very good.
Offline harlemex
« Reply #47 on: 19 May 2013, 16:08 »
amazing how much help people offer you because you are a woman  :wink: :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #48 on: 19 May 2013, 19:59 »
48 replies and counting
Offline james2
  • No scammers please.
« Reply #49 on: 19 May 2013, 21:13 »
change the thermostat first.  :whistle:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
