Author Topic: Scott's Mk4 GT28RS Build  (Read 165785 times)
Offline Scott-R
  • GoT BoosT!
Re: Just a sneaky peak!
« Reply #10 on: 12 May 2013, 10:37 »
Once again finding myself getting more and more done as the car is in the garage ha but should hopefully all be worth it when it's done not long now!!!!!
Some pics
Found that the boot and around the boot handle had a lot of rust and scratches soooo...
Here's before,
Inside lip of boot.
Boot handle.
Getting in about it ha
Same with boot handle.
Looking much better now.
Sorted then sealed.
Then rear bumper off for smoothing.
Any dinks or dings filled and prepped.
Then bonnet was given same treatment with every little chile etc getting attention.... :cool:
That's the body work side of things the engine I now back in and so is the interior, new headlights have arrived as have alooot of little touches etc ha
Thanks has to go again to Jaime at Apw in Blair athol who is keeping it all together with my ideas coming from everywhere and my constant nonsense in workshop ha
Shouldn't be long now hoping to get in touch with a magazine before the car gets driven on the road to see if they want to take some pictures of my little beast ha  :whistle:
Golf GTI ... What else would you have?
Offline Chris#101
« Reply #11 on: 14 May 2013, 20:05 »
this is going to look so fresh when its done  :cool:
any more details on that clutch bud  :smiley: ?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Granta Gti
« Reply #12 on: 14 May 2013, 20:22 »
loads of work here! cant wait to see it done
Offline Scott-R
  • GoT BoosT!
« Reply #13 on: 14 May 2013, 20:28 »
Haven't written the code but its a black diamond stage 2 clutch for the O2M box and it fits so I would go for that one and with it being hydraulic it won't be heavy on the foot!
I will try again to get the number!
If you can wait then I will you exactly how it is in very soon ha
« Reply #14 on: 14 May 2013, 21:39 »
Looking forward to seeing the end result :afro:
Offline Chris#101
« Reply #15 on: 15 May 2013, 18:18 »
What shop did you buy it from? Have you got a link?
Are you still running the standard dual mass flywheel?
 :smiley:
Offline Scott-R
  • GoT BoosT!
« Reply #16 on: 15 May 2013, 21:45 »
Chris I got mine through my garage but I will try get the item code from the box next time I'm there.
Yes I wanted to keep the dual mass and not go lightened for better torque at low revs!
It will be soo much better when I get it on the road again I can let yu know if its any good ha
Offline Scott-R
  • GoT BoosT!
« Reply #17 on: 23 May 2013, 20:32 »
Another little update.
Masked up for primer,
And some lovely primer!!
Looking at tomorrow to mask off car for painting and maybe some colour soon  :evil:
Again thanks goes to Jamie at APW Blair Athol.
Getting excited now  :cool:
Offline Scott D
« Reply #18 on: 24 May 2013, 17:24 »
fair amount of work going into this :)
what colour you going for?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #19 on: 24 May 2013, 17:50 »
This!
I hope it a real loud colour! Stand out from the crowd!!  :cool:
