Author Topic: Bulbs  (Read 3336 times)
Offline dubber36
Re: Bulbs
« Reply #10 on: 06 April 2013, 18:45 »
Osram Nightbreakers are whiter than standard, but don't expect them to be as crisp as xenons.
I've heard very good things about Mtec bulbs http://www.hids-direct.co.uk/categories/mtec-bulbs
Offline jonesltd
  • MK7 R
Re: Bulbs
« Reply #11 on: 06 April 2013, 19:32 »
First picture I used H7 100w ice halogen white bulb. That wrong?
Second picture is what I am talking about!!! Which bulb on the website? Sorry to be a pest/prat
« Last Edit: 06 April 2013, 19:51 by jonesltd »
If you cant find it......Grind it
Offline dubber36
Re: Bulbs
« Reply #12 on: 06 April 2013, 20:14 »
The second pic is just 501 parking lights, not the Mk6's DRL/Main beam.
Offline jonesltd
  • MK7 R
Re: Bulbs
« Reply #13 on: 07 April 2013, 07:22 »
501 w5w yes I have the side light for that but there are two bulbs within the second pic for mk6 and I am after the larger bulb which I have ordered the h15 bulb from the website? That wrong? If so what actual number do I need for the larger bulb in the second picture?
Offline andyr
Re: Bulbs
« Reply #14 on: 07 April 2013, 08:09 »
You've also got to remember that 100w bulbs are illegal for road use in the UK! IIRC 55w is the top limit.
As Dubber has also mentioned, the current draw will be far in excess of standard 55w bulbs and you run the risk of either/and   burning out the wiring to the bulbs/melting the plastic of the surrounding headlamp!  :shocked:
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline Jimble
Re: Bulbs
« Reply #15 on: 07 April 2013, 08:21 »
H15 is the DRL/Main beam bulb (large one). Although there is no whiter halogen replacement available for this.
W5W is the sidelight bulb.
H7 is the dipped beam bulb.
