Author Topic: air con radiator  (Read 728 times)
Offline Scott D
air con radiator
« on: 05 April 2013, 00:12 »
I've not had working aircon for too long now after misjudging a suitable gap between the raid and FMIC which ended up damaging the AC raid causing a leak   :grin:
Are all radiators the same over golf models and does it matter if from a AC or climatronic car?
Cheers,
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Benny.banks
Re: air con radiator
« Reply #1 on: 05 April 2013, 00:20 »
im removing mine soon your welcome come get it.
Offline Scott D
« Reply #2 on: 05 April 2013, 00:24 »
let me know when mate as will be down your way in a few weeks time if not managed to get one by then
