Author Topic: holy cr*p.  (Read 1802 times)
Offline Chris#101
Re: holy cr*p.
« Reply #10 on: 04 April 2013, 21:09 »
Scott the vr6 clutch set up won't fit our auq's because of our 6 speed box  :cry:
I've looked long and hard for an aftermarket clutch but can't find any  :undecided: which is annoying because I've got a 260 bhp and 290 lbs ft set up waiting to map in but there's no ways standard clutch will take it
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Scott-R
  • GoT BoosT!
Re: holy cr*p.
« Reply #11 on: 04 April 2013, 21:54 »
AUQ all the way! What about a black diamond setup? Says AUQ on the setup?
Golf GTI ... What else would you have?
Offline GTi_James
Re: holy cr*p.
« Reply #12 on: 04 April 2013, 21:57 »
Offline Scott-R
  • GoT BoosT!
Re: holy cr*p.
« Reply #13 on: 04 April 2013, 22:06 »
Doesn't say AUQ on that site..
Offline Chris#101
Re: holy cr*p.
« Reply #14 on: 04 April 2013, 22:34 »
That's what through me from the dark side website as there all listed for diesels :undecided:
Have you got a link where you got yours Scott?
Offline Scott D
Re: holy cr*p.
« Reply #15 on: 05 April 2013, 00:22 »
Sachs do a good kit for petrol 02M that can handle a lot of abuse although the lightweight flywheel can cause a bearing on the input shaft to come loose over time which is not a cheap to fix to have the box modifed.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline GTi_James
Re: holy cr*p.
« Reply #16 on: 05 April 2013, 07:59 »
ahhhh i got confused with the AGU engine, sorry fellas
