Author Topic: Stop, for the love of all that is good & holy: STOP!  (Read 1728 times)
Offline Immortal
  • 1.8 Turbo GTI (AUM)
Re: Stop, for the love of all that is good & holy: STOP!
« Reply #10 on: 01 April 2013, 12:58 »
A little experimenting has lead me to the cause.
Checked & double checked the hoses leading to the servo (all ok). Then decided to do the good old test on it: engine of & pump the break till the vacuum is exhausted, then holding the pedal down turn the ignition on, pedal should give as the vacuum builds up. Which it did until the revs dropped to 500rpm.
So the good news is that it is the engine speed that's the cause. The bad news is I've being fighting this rough running for a while...
Offline Chris#101
« Reply #11 on: 01 April 2013, 13:00 »
any fault codes?
have you tried unplugging the maf to see if it runs any better?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Immortal
« Reply #12 on: 01 April 2013, 13:04 »
Yes I have, I did it several times & it's hit & miss. Meaning sometimes it runs sweet without the MAF but not always
