Author Topic: Why Oh Why Oh Why ?  (Read 6271 times)
Offline welshdean
Re: Why Oh Why Oh Why ?
« Reply #40 on: 30 March 2013, 21:03 »
I understand that, but being a mk4 section I thought people would have had experienced this before. As the mk4 golfs sumps may be quite weak. Just like I found out that the mk4 golf have common problems with leaks.
So when the sump is hit, there might be a certain section that is prone to splitting or similar.
"surely, your not that stupid either "
Offline barrym381
« Reply #41 on: 30 March 2013, 21:07 »
most probably have but it would help if you looked at the sump for any damage before asking any1  :grin: :grin: the sump is not that big so you wont have to check much an if you have damaged it then this is probably why you have no oil pressure as there is no oil in it  :smiley: so get off your lazy arse go check
Offline welshdean
« Reply #42 on: 30 March 2013, 21:11 »
It's dark  :laugh:
Offline barrym381
« Reply #43 on: 30 March 2013, 21:12 »
It's dark  :laugh:
do you not know a torch gives light or is that your next question  :grin: :grin:
Offline welshdean
« Reply #44 on: 30 March 2013, 21:29 »
Where do I get a torch from and what batteries do I use
Offline barrym381
« Reply #45 on: 30 March 2013, 21:32 »
torch will be next to the tartan paint in any diy shop an are you old enough to be playing with batteries  :smiley:
Offline gm8
« Reply #46 on: 30 March 2013, 21:39 »
just run the engine till its really hot and all the offending oil has escaped. Then flush come ice cold water into the oil filler cap and look for the steam vent , this will definitely highlight the leak.........................................................  :evil:
Offline welshdean
« Reply #47 on: 30 March 2013, 21:51 »
Can't I just put a load of ice cubes in there instead, I've heard its good
Offline barrym381
« Reply #48 on: 30 March 2013, 21:53 »
that might work failing that try pissing in the wind  :grin:
Offline gm8
« Reply #49 on: 30 March 2013, 21:54 »
good way to get the pistons clean lol
