Author Topic: Forge TIP fitted. WOW  (Read 3685 times)
Offline Willows
Re: Forge TIP fitted. WOW
« Reply #10 on: 29 March 2013, 23:11 »
I've not changed anything as dn what I'm doing with the car so quite
Hard for me to tune it :/
Offline Dalo Harkin
« Reply #11 on: 30 March 2013, 08:14 »
Im seriously considering a 3"DP now, but really do t to loose any more low down grunt
A bigger downpipe just makes the turbo spool quicker and lets it breath more/faster, you shouldn't have lost low end poke from fitting a TIP though, you sure its all tight?
Offline paultownsend
« Reply #12 on: 30 March 2013, 09:21 »
Yeah it's airtight.
I think it's just because its smoothed out the power delivery. That bottom bit of the tip is a huge restriction
Offline xtetx
« Reply #13 on: 30 March 2013, 09:35 »
I need an AUM one too!
Offline davemk4
« Reply #14 on: 30 March 2013, 11:05 »
3" dp transformed my car. Sounds epic hearing more turbo noise and it picks up so well now
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline AD1.8T
« Reply #15 on: 02 April 2013, 20:35 »
Does anyone know if the tip listed on ebay will fit an aum engine ? Still no reply from them which is a tad annoying !
Offline Willows
« Reply #16 on: 02 April 2013, 21:02 »
I dn I got fed up and went and spent 409£ on there website for my car few more
Bits and stage 2 remap  :laugh:
Offline davemk4
« Reply #17 on: 03 April 2013, 15:36 »
Thought the other TIPs would fit just a different breather position or extra one or summit? :sad:
Offline AD1.8T
« Reply #18 on: 03 April 2013, 16:01 »
See this is what im unsure about just need comfirmation really
Offline Ashmond
  • Money, b!tches And Boost
« Reply #19 on: 03 April 2013, 16:55 »
I got a forge on mine, sounds the tits, much better then the standard!  :cool:
