Author Topic: creation motosport TIP quality issues!!!  (Read 2487 times)
Offline GTi_James
Re: creation motosport TIP quality issues!!!
« Reply #10 on: 31 March 2013, 14:38 »
i'd be pissed off lol
Offline davemk4
« Reply #11 on: 31 March 2013, 14:47 »
i am lol it just annoys me how they promote these things as perfec tfit etc. abit like mine been a AUM but i still need to bodge up and seal a breather with a bolt why not make the right one for a AUM without it! and the nipple near the bottom had nothing holding it in so as we pushed bottom pipe on the nipple fell into the TIP
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Nino
« Reply #12 on: 31 March 2013, 15:42 »
I got mine from them, mine is also an AUM and part from the coolent pipe being in the way and taking me about an hour getting it on it was a good setup, i didnt have to block anything up at all  :undecided:
Current - MK6 GTi Edition 35
Offline davemk4
« Reply #13 on: 31 March 2013, 15:47 »
this gets better. i had to block a pipe that came off right near the maf join. it knock on a metal valve next to the head of engine  :angry:
Offline Dalo Harkin
« Reply #14 on: 31 March 2013, 19:29 »
I think it is the setup like you said earlier, I noticed you still have the hardlines and the combi valve in, in all honesty, doing the SAI delete was one of the best mods I ever did, and frees up a load of room in the engine bay and will stop any further pipes rubbing on the TIP
Offline james2
  • No scammers please.
« Reply #15 on: 31 March 2013, 20:04 »
The joys of modding ,i left mine standard and have not had any problems.   :whistle:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline JimBR
« Reply #16 on: 01 April 2013, 20:03 »
You have an AGU. You wouldn't understand  :grin:
