Author Topic: Heated seats loom how to fit  (Read 2640 times)
Offline Callum_K
Re: Heated seats loom how to fit
« Reply #10 on: 09 April 2013, 15:57 »
If you have a complete loom it's pretty much plug n play, mine had been butchered. Will give more details later, about to leave work.
Offline xionsolaris
« Reply #11 on: 09 April 2013, 16:55 »
Cheers mate yeh its a complete loom the only wire thts been cut is the earth wire
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #12 on: 09 April 2013, 17:57 »
Piece of piss then.
Offline xionsolaris
« Reply #13 on: 09 April 2013, 18:11 »
So its just connect some plugs plug into seat and away u go warm bum
Offline Callum_K
« Reply #14 on: 10 April 2013, 08:21 »
Pretty much. Plug in to the seats, run the loom undre the little inner sill plastic panel and up behind the dash. You'll need to take out the clocks to wire it in. Partway up the loom should be 3 wires with plugs on end. Brown plug is earth, plugs in to a big round connector thingy on the A pillar but if it's cut just join it to any other earthing point. Behind and to the right of the clocks you should see a small block of different coloured connectors, your other two wires plug in here. Should be a black/white wire with green plug if I recall, plug in to the green one, this is your switched 12V. Blue/grey with blue connector goes in to the blue, this is your illumination.
Should all work as long as you have the relays and gubbins under the seats!
Offline xionsolaris
« Reply #15 on: 10 April 2013, 08:26 »
Cheers mate yeh all the seat electrics are there i hope the seats dont stink when heated up lol
