Author Topic: how much front camber  (Read 3108 times)
Gavv8
Re: how much front camber
« Reply #10 on: 26 March 2013, 19:01 »
If you set the struts at maximum negative camber they will both be the same as they'll only adjust so far, unless something else is bent on the suspension.
I'd advise getting it all set up professionally unless you really know what your doing or you'll end up with uneven tyre wear and possible handling issues, don't forget that with coilovers you lose a lot of compliance in the ride and handling and its important to get it right.
Offline tweed
« Reply #11 on: 26 March 2013, 19:18 »
I need to run mine all the way in  :wink:
If you had after market antirollbars and poly bushed then I wouldn't recommend it, also if you do a lot of motorway miles.
Gavv8
« Reply #12 on: 26 March 2013, 19:33 »
I must admit mine seemed to drive ok with them all the way in but it started scrubbing the inside edges of the tyres so i had to wind it out a bit.
Offline Screech16v
  • MK3 20vt AGU
« Reply #13 on: 26 March 2013, 21:33 »
Mine handled terrible   all the way in and 9" fronts .
Offline tweed
« Reply #14 on: 26 March 2013, 22:32 »
Twitchy?
Offline Ess_Three
« Reply #15 on: 26 March 2013, 22:37 »
I run somewhere between -1.6 and -1.8 degrees per side, toe out, with Koni coilovers, Eibach ARBs and Powerflex bushes and a Peloquin Diff...and get equal tyre wear.
Much of it depends on your driving style and vehicle use.
..but gaining motorcycles.
Gavv8
« Reply #16 on: 27 March 2013, 06:06 »
I'm guessing that diff makes a lot of difference though.
