Author Topic: Mk3 gti battery keeps going flat ...  (Read 2557 times)
Offline RainVonBee
Re: Mk3 gti battery keeps going flat ...
« Reply #10 on: 22 March 2013, 13:46 »
It could either be alternator or battery. Simple way to check the alternator is stick a multimeter on the battery and start the engine, the voltage should jump up to 14v  :) if not, it's a alternator fault :)
Golf mk2 1989 GTI 1.8 8V
Golf mk3 1997 GTI 2.0 8V Jazz Blue Colour Concept
Golf mk4 2000 1.6 16V SE
My babies :)
analogue_rogue
« Reply #11 on: 22 March 2013, 13:53 »
ignition off.
Remove positive terminal. connect multimeter set to amps between battery + and cable you removed.. take measurement.  Making sure you have a good connection (use croc clips if poss) turn ignition on and watch current draw.
Post readings .......
