Author Topic: Mk4 over fuelling backfiring choking itself please help  (Read 6290 times)
Offline Norfolknudger
Re: Mk4 over fuelling backfiring choking itself please help
« Reply #10 on: 28 March 2013, 18:54 »
Hi again going over to garage tomorrow going to clean maf sensor and check ignition amp to see if it helps fingers crossed :cool:
Offline Nino
« Reply #11 on: 28 March 2013, 18:59 »
good luck mate, you might of already done this but have you cleaned the TB?
Current - MK6 GTi Edition 35
« Reply #12 on: 03 April 2013, 18:27 »
Sorry fella I'm being a bit thick what's the TB do you men the turbo thanks for your help fella :laugh:
Offline dom
  • Back in a Mk4
« Reply #13 on: 03 April 2013, 19:52 »
TB = throttle body
« Reply #14 on: 06 April 2013, 12:19 »
Going to try another throttle body on Monday as just tried a new ignition amp and still the same :sick:
Offline Chris.
« Reply #15 on: 08 April 2013, 00:48 »
212bhp?  Stock turbo on AGU?
Could be signs of a weak fuel pump maybe?  Lean misfire.
Click For Build Thread
Offline james2
  • No scammers please.
« Reply #16 on: 08 April 2013, 23:02 »
no ones put a bit of diesel in it .
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline GTi_James
« Reply #17 on: 09 April 2013, 09:52 »
 :lipsrsealed:
« Reply #18 on: 13 April 2013, 22:48 »
No its had no diesel in it mate I thought of that as her indoors uses it more than me but she assures me she hasn't and mechanic has said it would smoke so I've taken this out of the equation as for fuel pump it could be that it's about the only thing I haven't tried yet my mechanic still hasn't changed the TB but has said he cleaned old throttle body and it ran spot on he tried it again the next day and it played up again so until he tries another clean TB I won't know but I will suggest the fuel pump to him and see what he says thanks for all your input fellas it is appreciated  :laugh:
« Reply #19 on: 21 April 2013, 23:07 »
Getting there cleaned throttle body and sensor both filthy car is now 98% better doesn't smell of petrol anymore but think this is because the hole in the intercooler pipe that had rubbed through whilst rubbing bulk head is now fixed but she seems a little bumpy when you lift of the throttle and it wouldn't let me accelerate to boost without a couple off blips on throttle after sitting at traffic lights for a while so think this could be caused by lazy pump as suggested but I'm nearly there now drove 40miles today and didn't miss a beat  :laugh: thanks again guys for all suggestions really has helped me out
