Author Topic: MK4 1.8T "STOP" on dash  (Read 3170 times)
Offline Cadde GTI Turbo
  • Caddie MK4 1.8TURBO
« on: 14 March 2013, 09:27 »
I have a problem when driving around the "STOP" light keeps coming on intermittently?
No other dash lights on, all oils coolants etc ok
Can anyone advise
Offline stfc_gti
Re: MK4 1.8T "STOP" on dash
« Reply #1 on: 14 March 2013, 09:32 »
have it scanned for codes.
check the coolant sensor, make sure its in tacked and not caked in crap.
had the same issue a few months back and the coolant sensor was the cause, along with the stat.
does your temp gague get to 90 and sit there or is it over/under 90?
2002 1.8T GTI AUM, Standard (not for much longer)
« Reply #2 on: 14 March 2013, 11:31 »
No temp is fine, had the water pump changed about 2 months ago. I plugged my code reader in but it found no faults.
Will check to coolant sensor
Offline navmk4gti
« Reply #3 on: 14 March 2013, 12:03 »
Clean the two metal prongs in the coolant bottle and check the sensor bud :smiley:
« Reply #4 on: 14 March 2013, 13:38 »
thanks guy's
« Reply #5 on: 16 March 2013, 13:25 »
Can anyone advise
Right guy's think I've found the problem, took the big plastic cover off the engine to take a look at the coolant sensor and found my cylinder head breather hose completely split open  :cry:
Offline dom
  • Back in a Mk4
« Reply #6 on: 16 March 2013, 14:06 »
Can anyone advise
Perfect time to fit a catch can :wink:
« Reply #7 on: 16 March 2013, 14:17 »
What is a catch can?
Offline dom
  • Back in a Mk4
« Reply #8 on: 16 March 2013, 14:40 »
Offline opel
« Reply #9 on: 16 March 2013, 20:11 »
I wouldn't think that would put stop light on tho. As I just replaced mine and my stop light wasn't on
