Author Topic: HELP HELP. CAR WONY START AND WHEN IT DOES SPLUTTERS AND DIES  (Read 1575 times)
Offline kingaz
The starter motor wont affect it once its running. You need to get diagonsitcs on it otherwise its just a guess, my guess would be injectors or maf.
For the moment, try unplugging the maf and seeing if that makes a difference
Right, inplugged the maf and it ticks over and runs... little bit lumpym but driveable. Is my maf f**ked then?
You can try cleaning it with some brake cleaner but it a temp solution...just get a new one, dont get the cheap ones either they dont last.
Happy that worked mate  :cool:
Cheers mate, just rung vw...128pound!!!
Offline dom
  • Back in a Mk4
It's worth getting one from VW though, I got a Bosch one from GSF and it lasted less than a year.
Offline Scott D
They should only be £100 if exchanging with the old unit from VW
Got one from ECP a Bosch and it faired slightly better, got two years before odd boosting and over reading  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline kingaz
Ahh didnt know u could do that.. still 100 quid though lol. How much was urs then?
