Author Topic: Engine frozen due to extreme cold  (Read 1804 times)
Offline itavaltalainen
Re: Engine frozen due to extreme cold
« Reply #10 on: 14 March 2013, 20:11 »
they are in the engine block... on the back... usually there is four of them....
e.g.
btw. even if it's not freezing you still need antifreeze in the system, it increases boil point and prevents corrosion and also lubes the water pump.... this is the reason you need at least 1/3 - better 1/2 - max 2/3 antifreeze in the mix...
« Last Edit: 14 March 2013, 20:12 by itavaltalainen »
Offline supramad77
« Reply #11 on: 14 March 2013, 20:56 »
Reason for not having any in was the car was sorn off rd while i was working on it but sadly it got real cold suddenly. Water pump was next to swap out.
Thanks for the pic.
Offline cobalt6700
« Reply #12 on: 14 March 2013, 21:03 »
Even more reason to put anti-freeze in it. Is it worth saving £20 to risk your engine?
Hopefully you've just popped a core plug ;)
1993 GTI 8v 5dr matt black and green - the 'sh!tball rally car'
1997 GTI 8v 3dr metalic black - the daily driver
2002 3DR 1.8T AUM silver - the new daily
1993 Jeep cherokee 4L - the weapon :D
