Author Topic: Golf Foglights centre bumper - Off fog headlight  (Read 1478 times)
Offline beaumontdvd
« on: 12 March 2013, 18:12 »
Hi All,
Basically I have foglights in the headlights,  these do not seem to improve much visibility however, and I like the look of the in the centre of the bumper,
I have a mk4 golf gti 1.8T (Intercooler on the left) so I cannot fit in the bumper sides. (Reason for deciding to mount to the middle)
Anyway,  I am looking at getting these http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_214268_langId_-1_categoryId_272450
And customizing the centre bumper insert to fit these, question is....  as I have foglights that are working and wired up to the interior switch currently,  can I not just take the live/negative off these and attach to my new fog lights.
Will this work with the switch aswell?  not to fussed about them working in the headlight and on the bumper,
Appreciate your help!
Thanks,
Dave
Offline dom
  • Back in a Mk4
Re: Golf Foglights centre bumper - Off fog headlight
« Reply #1 on: 12 March 2013, 18:18 »
To wire them in, just tap into the wiring for the existing fog lights. However, bearing in mind we don't actually have much fog in this country is it really worth it? Plus they will look crap :lipsrsealed:
Offline beaumontdvd
« Reply #2 on: 12 March 2013, 18:28 »
I quite like the look personaly  :cool: ill try tap into the existing then,  would this still work with the switch if I just take the live and negative?  We've had fog quite a bit down here in the last 2 years so it seems like a decent idea,  hopefully goes to plan,
Do you know of any foglights that would look better/perform better?
« Last Edit: 12 March 2013, 18:30 by beaumontdvd »
Offline GTi_James
« Reply #3 on: 12 March 2013, 19:42 »
into the fog lights lines with some wire splicers mate, will work as you turn on or off your fogs
Offline navmk4gti
« Reply #4 on: 12 March 2013, 21:20 »
U saying your going to put them in the centre lower grill?? :huh: :sick: :sick:
Offline beaumontdvd
« Reply #5 on: 12 March 2013, 21:31 »
Thanks James will do!
And I mean the bottom centre of the front bumper,
Will give it a go once ive found some nice ones,
Appreciate the help people, anyone know what colour the fog lights positive and negative are currently off the headlight loom?
Dave
Offline Nino
« Reply #6 on: 12 March 2013, 22:28 »
Has no one thought to say, that if he taps into the existing fog wiring that it might underpower the 4 fogs lights once there all on what I mean is for example there will be a certain ammount of Watts programed for the foglights then adding other 2 fog light will knock that watt in half meaning the bulbs will be underpowered and not be at there brightest settings?
Current - MK6 GTi Edition 35
Offline GTi_James
« Reply #7 on: 12 March 2013, 22:33 »
...oh yeah lol
you'll have to make a curcuite then from your battery to a control box, from your switch to the control box and then from your control box to the new lights, i would also see if there are any LED kits available as they use less power so if my first suggesting goes bang you've got a back up  :lipsrsealed:  :evil:
Offline dom
  • Back in a Mk4
« Reply #8 on: 12 March 2013, 22:40 »
I assumed that the bumper ones would replace the ones in the headlights and that you wouldn't need to run all 4
Offline Nino
« Reply #9 on: 12 March 2013, 22:47 »
I thought he wanted all four. My bad.
