Author Topic: Some jobs already  (Read 921 times)
Offline northeast_gti-t
  • "1.8T AGU"
Some jobs already
« on: 11 March 2013, 00:10 »
Well need to look at some jobs already  :grin:
I had a quick search around last night for relevant info and think i'm on the right tracks?
Gearstick sloppy (possible link and weight replacement?)
Temp Gauge issue (replace thermostat,and will replace thermostat cover housing too and replace with new G12 coolant)
Handbrake warning light on/no abs light (check needle in brake fluid res and top up to max as its on minimum,i know rear pads need changing or poss abs sensor? will be sorting vag-com onto laptop and sourcing a lead then scan it for any fault codes  :wink:)
they should keep me busy for now but are annoying as fcuk! and being me want them done,so any thoughts/comments welcome if i'm on the right tracks as the mk3 is new to me and i'll be learning as i go  :grin:
2000 Mkiv GTi 1.8T AGU
