Drilled and grooved disks are more suited to a track cars where you will be braking heavily corner after corner. The Benefits I believe are that they dissipate heat quick, therefore you should get less brake fade under heavy loads. Also maybe something about channelling brake dust away for the track pads which give off more 'dust', if you know what I mean.
Standard disks for road use will be more than fine.
