Author Topic: Clifford concept 50 led help!  (Read 2742 times)
Offline Deefadog
  • Mk2 16V (November 89)
Re: Clifford concept 50 led help!
« Reply #10 on: 30 July 2005, 11:52 »
Cheers mate!
Offline monzablue16v
« Reply #11 on: 31 July 2005, 12:27 »
U fixed it Deefadog????
Offline Deefadog
« Reply #12 on: 31 July 2005, 13:17 »
Sort of, i disconnected the battery and re-connected it, seens to be ok, except the cebtral locking don't work now!
Do you think there is a loose connection on the central locking?
« Reply #13 on: 31 July 2005, 17:18 »
no man probably need to change the locking from positive to negative or vice versa shud b in your install manual!!
u can do it!!!
Offline Deefadog
« Reply #14 on: 31 July 2005, 19:17 »
I have only the owners manual! I have not got the install one!
Why would this have changed? it has been working for well over a year, amd i have disconnected he battery many times before?
« Reply #15 on: 01 August 2005, 14:17 »
maybe a fuse went when you put it all back together? maybe it's just bloody Cliffrods they do what they want when they want and usually annoy the owner!!!!!!!
too damn clever they are thats why too damn clever! like when your rushing it knows to mess about with the auto immobilise just to wind you up!!!!
Offline Deefadog
« Reply #16 on: 02 August 2005, 13:07 »
Got to get this fixed :)
The central locking is the vacume type, and i believe only works from the drivers door.
Question - how does the alarm wire for the central locking connect to? is it the door or straight to the pump in the boot?
« Reply #17 on: 02 August 2005, 14:16 »
usually it's linked to a master motor in the drivers door so when you lock the alarm it pulls the drivers side lock closed and triggers the other locks as the drivers side is only a switch so you can lock all doors from the drivers door. or a motor in each door depends how it was fitted. You could try using the key to lock the drivers door if it works you've got a problem with your alarm and know where to start!!
Offline Deefadog
« Reply #18 on: 03 August 2005, 08:29 »
Thanks!
I think i found the problem! I think either the rod coming up is rubbing or getting stuck, or the motor is on it's way out! because sometimes it really makes a noise, and sometimes it does not?
Am i right in thinking that the motor is there just for the alarm? as i can activate the central locking with the key
