Author Topic: N249 fault?  (Read 11045 times)
Offline Ess_Three
N249 fault?
« on: 26 February 2013, 20:53 »
My car has done limited miles in the last few months...and it appears to be not to happy with being re-used!
I got an Engine Check Light and Limp Mode yesterday afternoon.
A scan with VCDS revealed a N249 problem.
Anyone had similar or know anything about it?
I cleared it and will see if it comes back, before a trip to the dealer.
Details as below:
008801 - Boost Pressure Control Valve (N249)
               P2261 - 000 - Mechanical Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 5
                    Mileage: 18964 km
                    Time Indication: 0
                    Date: 2097.14.18
                    Time: 15:18:00
             Freeze Frame:
                    RPM: 2882 /min
                    Load: 8.2 %
                    Speed: 98.0 km/h
                    Temperature: 53.0°C
                    Temperature: 4.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.224 V
..but gaining motorcycles.
Offline Snoopy
  • Moderator
  • Geoff.
Re: N249 fault?
« Reply #1 on: 26 February 2013, 22:31 »
Sounds too me like your dv valve has split.
I would remove it and check if it was me. It's only 3 screws and a plug.
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline Keithuk
Re: N249 fault?
« Reply #2 on: 01 March 2013, 01:16 »
VAG Error Code: 18693
EOBD II Error Code: P2261
Fault Location:
Boost Pressure Control Valve (N249) - Mechanical Malfunction
Possible Cause:
Boost Pressure Control Valve (N249) faulty.
Wiring/Connectors from/to Boost Pressure Control Valve (N249) faulty
Possible Solutions:
Check Boost Pressure Control Valve (N249).
Check Wiring/Connectors from/to Boost Pressure Control Valve (N249).
A taken from my EOBD II Fault Codes Software
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline ScottA
Re: N249 fault?
« Reply #3 on: 01 March 2013, 01:51 »
+1
Offline Neil gti
Re: N249 fault?
« Reply #4 on: 01 March 2013, 07:07 »
When my boost valve was split i didn't get any check engine lights on or limp mode ?
i just felt it was under powered and not boosting correctly, so the boost valve was my 1st port of call for inspection,
i would maybe check the wiring to it 1st as i have read somewhere that these have been getting stretched and splitting,
No check engine light on mine or limp mode when this happened to me ?
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline Ess_Three
Re: N249 fault?
« Reply #5 on: 01 March 2013, 10:00 »
I've reset the fault and drove the car today, with no limp mode.
I'll check for faults later.
It's under warranty still, so if the fault comes back, I'll book it in.
Offline Snoopy
  • Moderator
  • Geoff.
Re: N249 fault?
« Reply #6 on: 01 March 2013, 10:12 »
If it was me i would get under there and check its not like its that hard once you get under there.
You can see its location on my thread.
http://www.golfgtiforum.co.uk/index.php?topic=225620.0
Mk6 GTI  &  Mk1 GTI
Offline Ess_Three
Re: N249 fault?
« Reply #7 on: 02 March 2013, 11:53 »
I had a crawl under today to check:
The wiring is OK, not broken, cut or stretched.
The DV is a 'G' revision. Is this the latest type?
There appears to be no splits/stickiness in the DV.
The fault hasn't come back either...so I wonder if a long period of sitting has left something a little sticky, and it's freed off as soon as it's got properly hot and seen some proper boost.
All very odd.
Offline Neil gti
Re: N249 fault?
« Reply #8 on: 02 March 2013, 12:11 »
Hopefully just a glitch, sticking valve as you say, sounds like it needs a good blast out sticking to speed limits of course  :rolleyes: :whistle:
I replaced mine with Rev D so it's the latest version as far as I know
Loving the 7R
