Author Topic: cars topping out at 107mph  (Read 4319 times)
Offline MattyV6
  • Mk4 .:R32 - The Black Destroyer
Re: cars topping out at 107mph
« Reply #20 on: 27 February 2013, 09:39 »
A standard 1.8t should reach 130/140 right??
Not in any way standard :) Dyno Dynamics RR - 280bhp
Offline GTi_James
« Reply #21 on: 27 February 2013, 09:47 »
as long as you havent got any leaks 130 at least
Offline Jin_C
« Reply #22 on: 27 February 2013, 11:02 »
The limp mode in an AGU restricts boost and in-directly acceleration but does not directly limit total speed. If the car can get to 107 before limp mode kicks in it won't accelerate further due to limited boost. If the car is going faster than this limited boost can maintain it will begin to decelerate.
As far as I know the limp mode on all AGU's is temporary and can be reset by lifting your foot off the accelerator and re-applying. But if the conditions that caused the initial limp mode are still occurring it will go straight back into limp mode.
Like the others said, check for boost/vacuum leaks, stretched throttle cable (this can be adjusted using the holder that attaches to the inlet manifold)
I suffered from limp mode when my cat disintegrated and started to block my exhaust system. If you can, take it off and give it a shake and listen out for any rattles.
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline harlemex
« Reply #23 on: 27 February 2013, 17:26 »
Where did you get this info from?
Offline Jin_C
« Reply #24 on: 27 February 2013, 23:21 »
I had to do lots of research, asking questions on forums and testing when I kept on getting limp mode on my AGU. Got most of my information from other forum members.
Offline dan2252
« Reply #25 on: 27 February 2013, 23:43 »
Ok nice one.
Its dwad weird cus sumtimes in 1st and2nd it will rev right round..
You red line it?!!  :lipsrsealed:
1.8ts was made to red line!
MK4 golf 1.8 turbo agu :)
Offline GTi_James
« Reply #26 on: 28 February 2013, 08:37 »
Ok nice one.
think your confusing our motors with the RX8, if the mk4 was made to red line then our engines wouldnt crumble if it gets a sniff a heavy foot without some minor mods  :lipsrsealed:  :laugh:
