Author Topic: Other things I could try? Yes another stupid boost error  (Read 1904 times)
Offline Dalo Harkin
Re: Other things I could try? Yes another stupid boost error
« Reply #10 on: 26 February 2013, 12:14 »
Pressure drop is between Turbo and DV so can only be one of the pipes off the TIP
Offline Nino
« Reply #11 on: 26 February 2013, 13:12 »
I will check the TIP ASAP (pending a day off without rain) I have also changed the PCV pipe to silicone however I did notice that all the little pipes leading off the valves think that's the n249? Looked a little old and brittle but upon inspection I could not see any cuts/splits. Am I right in thinking I can just buy some 3mm silicone to replace all those little pipes?
I don't want to do a bypass or catch can thingy because a good number of times I have looked at tutorials and stuff and it just well confuses me and I know I would get something wrong lol.
I'm certain I am not getting limp mode as the car does feel quick if I floor it abit. The boost gadge reads when I floor it it can reach upto 8-10 psi then drops and holds at 5 also I can easily hit 100 which I found out while travelling home the other day and didn't realise how quick I was traveling which I then dropped it down to 70 so I think that rules out limp mode.
Current - MK6 GTi Edition 35
Offline GTi_James
« Reply #12 on: 26 February 2013, 14:19 »
easy enough job really, i did mine at my GF's cousins garage and had help if needed but for a complete amature i did it all in about an hour and a half  :wink: or just pay a garage an hours labour and they'll do it for you
Offline rio_gti
« Reply #13 on: 26 February 2013, 16:52 »
you had a remap yet??
Offline Nino
« Reply #14 on: 26 February 2013, 18:10 »
