Author Topic: ABS problems - light not working - '96 VR6  (Read 5416 times)
Offline silverfox
Re: ABS problems - light not working - '96 VR6
« Reply #10 on: 30 July 2005, 22:07 »
Well, after a trip to Maplins and a bit of soldering, i now have 2 working lights  :smiley:
and 2 fault conditions  :sad:
Ady is going to assist in tracing the ABS fault, any ideas as to why the Airbag could be showing a fault?
silent-hunter
« Reply #11 on: 31 July 2005, 00:13 »
At £60 ish  a corner for good sensors you wanna be keeping the fingers crossed.. :sad:
Code reader will tell you more though.. :sad:
Offline silverfox
« Reply #12 on: 03 August 2005, 09:44 »
Ady and his trusty laptop tracked it down to be the right rear sensor. and the airbag fault says - resistance too high!!! whatever that means. But at least i can get the sensor changed and get it through the mot now.
Offline adyh
« Reply #13 on: 04 August 2005, 12:38 »
Ive checked on the internet about the airbag issue and its to do with the ignitor circuit . I wonder , as you said , whether the thing has gone off before .
All other codes , cleared when i reset them so i reckon they are not a problem .
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« Reply #14 on: 04 August 2005, 15:24 »
yeah hopefully nick can then join us at some meets and shows... Good to c ur using the forum Nick... Welcome to the Club/forum mate... Say hi to the family for me....
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline silverfox
« Reply #15 on: 05 August 2005, 18:45 »
Well i replaced the sensor, but the ABS light is still on, showing a fault. :cry:
Does it need to be plugged in to the VAGCOM to clear the fault condition or should it clear automatically?
Offline kr1s77
« Reply #16 on: 06 August 2005, 10:25 »
Nah, if the sensor you changed was the fault, then the light should go out automatically, after driving about a mile or so (well thats what happened when i did my n/r sensor). Mines a 1997 8v gti, not sure if the system is the same, but i don't see why it would be different
Hope you get it sorted
« Last Edit: 06 August 2005, 10:27 by kr1s77 »
ASV 1.9 TDI 110
Offline silverfox
« Reply #17 on: 12 August 2005, 12:13 »
Well i gave up trying to fix it, and took it to my local VW dealer for a diagnostic check.
They worked on it for a day, and eventually told me that it wasnt the sensor as the computer showed, but in fact a fault on the ABS ECU, it wasnt reading from the sensor, price to repair £600  :shocked:
But after all the work they did tracing the problem, they didnt charge a penny  :smiley:
So i now have to source an ABS ECU.
I tried BBA-reman, £130 to fix mine, gonna look for a secondhand one first i think.
it goes on .................
does anybody know if the ABS ECU is the same one on any other models, or is it specific to the VR6?
Offline Overseer
« Reply #18 on: 12 August 2005, 15:50 »
^ for a new ECU try people breaking mk3's on ebay..
