Author Topic: intermittent misfire after remapped ecu?  (Read 6143 times)
Offline azzsmith
Re: misfire after remapped ecu?
« Reply #10 on: 22 February 2013, 22:30 »
Ok thanks topher, do you think a 4bar fpr would be needed?
The car the ecu came from had one.  :huh:
black magic agu 240bhp
Offline topher
  • Administrator
  • fully functioning
« Reply #11 on: 22 February 2013, 23:23 »
i dont know if the injectors maxing out with that fpr in will cause a lean enough condition for the backfires.. thats usually more a sign of weak flow from the pump. Or sometimes even lean running from massive overboost will do it. still, if you have free access to a 4 bar fpr its worth trying. even if it feels better i'd get it checked out properly before trusting the map to be fully compatible with your hardware
Offline azzsmith
« Reply #12 on: 22 February 2013, 23:26 »
Ok mate, weird thing is it only does it on really hash acceleration, if i drive "normally" its fine!
Offline Chris.
« Reply #13 on: 23 February 2013, 00:03 »
Sounds like a lean misfire from my experience.  had the same issue...under load it misfired, partial load it was fine.
Could also be a coil breaking down, I had that too.
Id be starting with the fuel pump like Topher said.  Get rail pressure logged on a dyno and make sure all is fine.
Click For Build Thread
Offline azzsmith
« Reply #14 on: 23 February 2013, 00:30 »
Thanks chris... should have mentioned that before i put remapped ecu in it was boosting to 0.7bar and now it's 1.3bar, does that sound about right?
Offline Chris.
« Reply #15 on: 23 February 2013, 00:33 »
18psi sounds good.
just careful when its misfiring....dont want anything melted.
Offline azzsmith
« Reply #16 on: 23 February 2013, 00:36 »
MELTED?!  :shocked:
Do you think i should try putting in calibra injectors? I have them in the boot lol.
Offline Chris.
« Reply #17 on: 23 February 2013, 00:38 »
No, probably make it worse.
If its your pump weak, like i suspect...only thing is a replacement intank pump, or put old ECU back on until you upgrade.
I cant see the FPR making a difference as 4bar gives 15% more fuel in theory.
Offline azzsmith
« Reply #18 on: 23 February 2013, 00:43 »
Ok thanks chris, I was gonna buy a replacement coil pack tommorrow from vw and try that but should I try fuel pump first or maybe ignition amp?
The only reason I say about the injectors is that baxxy thinks the car it came off had bigger injectors but hes not 100%  :huh:
Offline Chris.
« Reply #19 on: 23 February 2013, 00:46 »
Doubt its either, ignition amp usually go all the time causing continous misfire.
What injectors were in the car?  Could well be a overfuel now you have suggested that.  You would NEED to use exact same injectors as what the ECU was mapped on.
