Author Topic: How do i make my car so i can hear it boosting and chattering?  (Read 2783 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: How do i make my car so i can hear it boosting and chattering?
« Reply #20 on: 23 February 2013, 08:16 »
the ko3s is bigger its the one you get on the 180bhp golfs us 150bhp boys have ko3
No the 150bhp golf's have K03s too. K03s only has a slightly bigger compressor wheel and stronger actuator, nothing else. It's physically the same size
Offline paultownsend
« Reply #21 on: 23 February 2013, 09:07 »
For a cheap mod I got a spare air box, and basically chopped off the bottom part around the inner wing at battery. PiperX panel filter.
Logged through VCDS it pulled an extra 8g/s and no increase in heat.
Sounds great now. Loads is spool and dump noise.
I also think that the std intake is too restrictive. Even with the DSG mod it's pulling air through an awkward route. So I use it more as a cold air feed.
Offline kingaz
« Reply #22 on: 23 February 2013, 15:47 »
That sounds a plan actually. So just whip the airbox off and chop a big hole in he bottom?
Offline Dalo Harkin
« Reply #23 on: 23 February 2013, 19:47 »
But you still need to spend £40 odd on a decent panel filter, have a search on here for what others have done, a cone on the end of the MAF will give you the noise you want, but you'll need to shield it from the heat of the engine and provide a cold air feed to it
