Author Topic: HELP! NO BOOST AND OIL PRESSURE LIGHT COMING ON  (Read 3727 times)
Offline barrym381
Re: HELP! NO BOOST AND OIL PRESSURE LIGHT COMING ON
« Reply #10 on: 21 February 2013, 00:06 »
How far you drove it an does it sound like a tractor yet
Offline kingaz
« Reply #11 on: 21 February 2013, 00:24 »
220 miles and nah it sounds fine still. Home now, will let u all know what the problem was tmoz
Offline barrym381
« Reply #12 on: 21 February 2013, 01:01 »
Get the sump off check the pick up pipe
Offline kingaz
« Reply #13 on: 21 February 2013, 01:41 »
Will have to get the garage to do it mate. Im not mechanically minded and dont have tools lol
Offline barrym381
« Reply #14 on: 21 February 2013, 01:59 »
Be ready to have your pants pulled down an taken from the rear   :cry:
Offline Nino
« Reply #15 on: 21 February 2013, 07:58 »
If your oil pickup pipe is blocked no oil can get to the turbo which in the end means a sneezed engine  :cry:
The fact that it only happens at 4k would tell me that its half blocked defo check that pipe and change it its an easy job.
* go to VW buy oil pickup pipe, 5l of 5w 40 oil, oil filter, sump plug and sump sealant this will set you back £62.86 (did all mine last week)
* drain your oil and wip off your sump.
* onbolt you oil pickup pipe and put new one on.
* clean your sump and take off any old sealant.
* re-apply your new sealant and bolt on your sump. (Don't be scared to use a lot of sealant)
* leave the sealant to set I left mine overnight.
* take off your old oil filter and replace with new one remembering to half fill the oil filter with fresh oil and rub fresh oil around the seal to create a good seal when you tighten it up.
* add your new oil remember to unplug the dip stick to avoid any air locks..
Hopefully this will sort your problem. :)
Current - MK6 GTi Edition 35
Offline stfc_gti
« Reply #16 on: 21 February 2013, 13:17 »
umm, you realise you have just admitted a number or time you have been breaking the law.
2002 1.8T GTI AUM, Standard (not for much longer)
Offline Dalo Harkin
« Reply #17 on: 23 February 2013, 19:35 »
 :grin: :whistle: :lipsrsealed:
Offline kingaz
« Reply #18 on: 23 February 2013, 21:15 »
Car is fixed  :laugh:
Offline barrym381
« Reply #19 on: 23 February 2013, 21:18 »
an your wallet is now a good bit lighter  :grin: :grin: an ready for the next problem a hope  :smug:
