Author Topic: No time - No More Money To Waste...  (Read 7086 times)
Offline dom
  • Back in a Mk4
Re: No time - No More Money To Waste...
« Reply #10 on: 21 February 2013, 08:39 »
What is your car doing?, what parts have you replaced so far?,
I had some running issues with mine, took me a good few months to put right, and it's fixed now.
And your right, some mechanics from dews are cowboys.
Who do you take your car to btw?, I'm sure it'll be an easy fix.
This. What makes your mechanics think that the engine is on its way out? What is the car doing that is wrong, and what have you done to try and fix it so far?
Offline GOLF-MK3-GTI
« Reply #11 on: 21 February 2013, 09:50 »
Itteh is a local lad, I've seen his car a few times, If he wants ill have a look to see what is wrong with it  :wink:
Offline boneybradley
  • Back in a Mk3...
« Reply #12 on: 21 February 2013, 09:52 »
an engine from a breaker is only £100........ although looking at the posts you've made it sounds like it's not terminal (more bolt on parts or electrical issues)
« Reply #13 on: 21 February 2013, 10:21 »
Reading back your previous posts, You mention that the engine keeps switching off?
Right i had this same problem with mine, It was the crank shaft sensor.
I cleaned all the earths, But did not make a difference. apart from my lights getting brighter.
I went through 3 different coil packs, But problem was still there.
I did not change the relays, But started car from stone cold and touched relays after 10 - 15 mins of driving, and they were hot enough to touch, So it was not the relays too.
I changed the distributor car & rotor arm, that did not help aswell.
I didn't clean the throttle body, so i knew the problem wasn't there.
I checked all the bretaher pipes, and they were all bang on.
Last thing to check was before it went to the scrappy was.... CRANK SHAFT SENSOR. and it turned out to be that. The wires were completely detoriated.
So i replaced that, with a new part from GSF and i've done over 3000 miles since. NOT GAVE ME A PROBLEM SO FAR. Touch Wood.
My car kept on turning off at traffic lights and would not start until left for abit. and sometimes i could be driving it all day and when coming to switching it off, it would not start up.
Question for you Itteh?, When your car turns off, Does the oil light flash? and do the revs go all over the place?
Also your car giving you dirty mileage, I would put that down to, Breather Pipes, Oil Service and possibly get a new ECU Temp sensor.
and as it stands about that little sensor, I would say that its got nothing to with the car cutting out on you. Like you say its been like that since last year, but never gave you a problem. However it will play a little part in giving you dirty mileage, But not alot.
Its an easy fix, I'll tell you that...  :wink:
« Last Edit: 21 February 2013, 10:51 by GOLF-MK3-GTI »
Offline Len
« Reply #14 on: 21 February 2013, 12:39 »
But his parents and brother know more about his car than we do, so he's not listening!
www.sas.org.uk
www.the-ace.org.uk
Offline danmusic24
« Reply #15 on: 21 February 2013, 16:59 »
Stop being a tit and just sort it out. If my parents gave me lectures on my car I'd tell them to do one.
:grin: :grin: :grin:made my day!!!
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #16 on: 21 February 2013, 17:47 »
Just to chirp in  :grin:.If anyone saw a pic of ltteh's induction kit they could see the last owner disconnected the air intake temperature sensor and fitted some little effing filter in place.He told me he found the cable tucked under the arch,so first thing i would suggest is fitting a new sensor and plug it back into the shoulder of the air filter.By taking it to a numpty non VW mechanic what do you expect them to say  :lipsrsealed:
Offline dom
  • Back in a Mk4
« Reply #17 on: 21 February 2013, 18:48 »
Yeah I had a trawl back through his previous posts, that would be my first port of call. You can lead a horse to water...
Offline CJA321
« Reply #18 on: 21 February 2013, 18:55 »
Exactly... Seems been given some very good advice tbh, must just not want to take it in!
Gavv8
« Reply #19 on: 21 February 2013, 19:35 »
Itteh.. you need to get a grip...focus on the problem and remember.. a golf is for life not just summer romance, listen to the people offering help/guidance and advice because they DO know what they are talking about... follow the path back to mk3 happiness....
