Author Topic: wet floor & carpets.. weld up drain plug holes?  (Read 4603 times)
Offline Len
Re: wet floor & carpets.. weld up drain plug holes?
« Reply #10 on: 20 February 2013, 10:30 »
You 100% certain that that's where the water is coming from?
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #11 on: 20 February 2013, 10:31 »
Have you checked your pollen filter recently?
Or......
www.sas.org.uk
www.the-ace.org.uk
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #12 on: 20 February 2013, 10:50 »
Don't tease your Mk3 with the welder unless it really needs it. There are easier ways to seal up a hole.
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #13 on: 20 February 2013, 13:09 »
yep think welding is a bit ott.. yeah the wetness is definitely coming from the floor but it'll be also coming from the pollen filter because the plastic seal/cover there is broken.
made 5 50mm circles from 2mm steel and siliconed them in today so should have no more wet and no more frozen inside of the windscreen. made 5 more to do the passenger side while the center console is out too
Offline tshirt2k
  • Been there...Done that...
« Reply #14 on: 20 February 2013, 15:11 »
Untreated steel? You may have to weld it up after all. As said previous, don't get the welder out unless you have to. Should have got a grommet from a breaker or someone could have sent you some for the price of a stamp.
Mk3 ABF 16VT Megasquirt V3
