Author Topic: Relay 109  (Read 2955 times)
Offline dane
Relay 109
« on: 18 February 2013, 23:03 »
Iv been told this relay is fuel pump but its come up with ecu engine module so witch is it and what problems would it cause please can some one help i just get told loads of diffident things told to me from garages and any idears why iv never hear my fan work temp go up to 90 then when I put heating on it god right back down
Offline beppe2672
Re: Relay 109
« Reply #1 on: 19 February 2013, 10:03 »
Relay 109 is your main ecu power relay.
Here are the Relay 109 Circuits: (stolen from another forum)
Relay 109 and associated Circuits Located at Position 12 in the upper relay panel.
Relay 109 is identified as J317, Power Supply from Terminal B+ (hot at all times) with power activation from the ECU when the key is in the ON position
Power Circuit to Relay 109
1. Power (6.0 size red wire) comes from Fuse S176 (110amps) at the plastic box on battery to Threaded Connection 500 at the relay plate -1- (30).
2. From the Relay Plate, at Connection 501 the power (6.0 size red wire) goes to Splice A98
3. From Splice A98, the power (4.0 size red wire) goes to Terminal 2/30 of Relay 109
Relay Circuit (activated when the Ignition is turned on)
1. Connection 9/85 goes to Blue Connector T10h/8 on to ECU at T121/18
Power Circuit away from Relay 109
1. Power away from Relay 109 is via 4.0 Blue Wire to Splice A71
2. At Splice A71, there are three circuit branches (A, B, & C, my terminology)
Circuit - A. 1.5 Wire goes to Fuse 34 (10 amp)
Circuit - B. 4.0 Wire goes to Fuse 32 (30 amp)
Circuit - C. 1.5 Wire goes to Fuse 43 (10 amp)
Circuit A (with two branches) ........ engine operation functions
From Fuse 34 goes to Splice 100, first branch provides power to: MAF (G70), Wastegate Bypass Regulator Valve (N75), EGR Vacuum Solenoid Valve (N18) and Change-over Valve for intake manifold flap (N239) Note: tied to this same circuit, is another circuit that comes from a 1.0 size wire from connection 6/87 of the GP relay. The second branch , Splice 100, goes to the 14 Pin Connector at T14a/6 on to Cold Start Injector (N108)
Circuit B (with two branches)
From Fuse 32 goes to Splice B168, first branch (4.0 wire) goes to Brown Connector point T6/4 on to splice D74 and provides power to: ECU at T121/1 and T121/2 via the two branches at Splice D74. The second branch goes to the 10 pin connector at the Injection Pump (G149), connection T10f/5
Circuit C (with three branches)
From Fuse 43 goes to Splice A155 , the first branch goes to Clutch Vacuum Vent Switch (F36). The second branch (page 10) goes to Brown Connector at T6/6 with double wire of which one goes to a 53 Relay J359 for Low Heat Coolant GP and the other goes to the Positive Crankcase Ventilation Heating Element (N79). The third branch goes to the Brake Vacuum Vent Valve Switch (F47)
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline beppe2672
Re: Relay 109
« Reply #2 on: 19 February 2013, 10:07 »
also I believe relay 109 is diesel only.
Offline dane
Re: Relay 109
« Reply #3 on: 19 February 2013, 14:33 »
Thanks just iv been told that its the 109 I need and that is for the fuel pump and now I don't no how to no what one I need ha it's ticking like a time bomb lol and when we plugged the computer in to test y I haven't been hering my fans it went mad then after I couldn't start car please can some one help I'm at my last end with it just want my car running right again
