Author Topic: Golf gti mk3 16v ABS problem again but with a difference!  (Read 3952 times)
Offline dragongreengolfgti
  • my golf gti mk3
Re: Golf gti mk3 16v ABS problem again but with a difference!
« Reply #10 on: 19 February 2013, 22:08 »
The sensors should measure between 1k and 1.3k ohms.
You should have checked continuity of the pins after soldering, you may not have done the job right as the solder needs to flow.
Nice one i shall check all this i am going to do my second ecu this weekend and check it properly this time I think i shall check all the sensors at the wheels aswell before doing anything further cheers
