Author Topic: GTI 16v fan not coming on?  (Read 4181 times)
Offline Djmac
Re: GTI 16v fan not coming on?
« Reply #10 on: 19 February 2013, 11:23 »
Ive solved the starting issue, turned out it was my coil lol! Must have been on the blink then finally went! Hopefully solve the bogging issue i had at 3k! I got told by a mechanic that it could be as simple as the sensor in the rad thats causing the fan not too come on? Anyone had this issue? Could it be a thermostat issue? Is it easy to change a thermostat on the 16v? Thanks for the feedback, much apreciated! Dan
Gavv8
« Reply #11 on: 19 February 2013, 11:40 »
Does the gauge sit in the middle once its warmed up properly?, if so your thermostat is fine and if you need to change it then its a bit fiddly but fairly straightforward.
It could be the fan temp sensor on the rad or even the fan motor itself.
Offline Len
« Reply #12 on: 19 February 2013, 12:42 »
bogging issue at 3k could be ECU relay
www.sas.org.uk
www.the-ace.org.uk
Offline Djmac
« Reply #13 on: 19 February 2013, 12:56 »
Im waiting for my new rad, sensor and fan to arrive! Im also waiting for my new coil as that is why it wouldnt start! One i have them put on ill run it out and see where the temp is staying aswell as seeing if the bogging issue is there! Thanks alot been a great help!
Gavv8
« Reply #14 on: 19 February 2013, 13:10 »
I'd do the thermostat too while your doing the rad then you know its good and you won't have to drain the cooling system twice.
Offline GOLF-MK3-GTI
« Reply #15 on: 19 February 2013, 13:43 »
There is a video on youtube, which shows how to check if fan is working.
Link: http://www.youtube.com/watch?v=JZCrTHcXo6Y
Offline Djmac
« Reply #16 on: 19 February 2013, 14:21 »
Thanks for the video link, great help! Tested the fan like in the video and the 2 speeds work! Does this diagnose why the fan isnt coming on at temp? Thanks again
« Reply #17 on: 19 February 2013, 14:57 »
I'm not sure on this one, but can it not be the temp sensor thats in the flange in front of engine.
wait for someone to confirm this, like i've said i ain't sure on this
.   :lipsrsealed:
On second thoughts, I think your fan switch is faulty, Have you replaced this??
« Last Edit: 19 February 2013, 15:16 by GOLF-MK3-GTI »
Offline Djmac
« Reply #18 on: 19 February 2013, 15:47 »
I haven't replaced anything yet? i've baught a radiator and fan combo, the rad comes with the sensor in, but im not sure of what switch you mean? Cheers
« Reply #19 on: 19 February 2013, 15:57 »
I have my doubts on the fan control module, Its located under the coolant bottle.
