Author Topic: Gunk in reservoir  (Read 2498 times)
Offline gamestaffords
Re: Gunk in reservoir
« Reply #10 on: 11 February 2013, 06:15 »
Hang on, is it gunk in the coolant reservoir?
I'd assumed oil filler cap, but re-reading it would appear that it might be :lipsrsealed:
Oh dear  :undecided:
that dont sound good?? is that the verdict?
Offline dom
  • Back in a Mk4
« Reply #11 on: 11 February 2013, 07:20 »
Oh dear  :undecided:
Is the gunk in the coolant reservoir then? How old is the coolant?
« Reply #12 on: 11 February 2013, 08:31 »
yea in the coolant i changed it about 2 weeks ago with the thermostat,temp sender and sender housing, reading other posts i think it could be the oil cooler,im going to look at prices today
Offline beppe2672
« Reply #13 on: 11 February 2013, 12:57 »
Did you put the same coolant in as you had before? I know if you mix long life coolant and normal stuff it can go cloudy and eventually cause a brownish sludge to form.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline DubAndDubber
« Reply #14 on: 11 February 2013, 13:01 »
That'll take years, if its sludge in the water you have oil contamination..
Mk5 Golf Gti 06'
« Reply #15 on: 11 February 2013, 14:07 »
thanks for your help going to change the cooler this afternoon got the part from the breakers £35 vw wanted £125+vat ill let you all no how it goes
Offline Mk2_tel
« Reply #16 on: 12 February 2013, 18:19 »
I had same thing to be honest and it was head gasket
After a while I started to get a water leak where it was boiling out overflow
I did 29k with this problem and the hole time I had no obvious head gasket signs
« Reply #17 on: 31 March 2013, 15:38 »
Hi,,just to let you all no, an oil cooler and header tank from the breakers some rad flush and engine flush new filter,oil and coolant later and problem looks sorted thanks for the advice
