Author Topic: Jdmhondaparts 3" Ebay exhaust fitting problems  (Read 2353 times)
Offline gt130dave
Re: Jdmhondaparts 3" Ebay exhaust fitting problems
« Reply #10 on: 10 February 2013, 20:10 »
Well looks neat m8 :cool:
Offline baxxy
« Reply #11 on: 10 February 2013, 20:48 »
How comes these pipes didn't come pre drilled for the senders i bought a 3" down pipe and D cat off eBay for £80 and it fitted straight onto my auq no problems at all senders was in same place as me original pipe
Offline Gary022
« Reply #12 on: 10 February 2013, 20:56 »
It has come pre drilled but where they are is wrong for my car. Mine is a aum but as the pictures show it doesn't fit to allow the sensors
Mk4 Golf Gti 1.8T
Custom K&N CAI / Forge 008dv / 3" Turbo Back Exhaust with Highflow Sports Cat / Pressed Plates / Carbon Wrapped Interior Trim / 18" BBS CH Reps
Offline baxxy
« Reply #13 on: 10 February 2013, 21:05 »
Sounds like they have sent you the wrong down pipe mate
if i was you i would buy a 3" down pipe and D cat off ebay that will fix your problem
« Last Edit: 10 February 2013, 21:08 by baxxy »
Offline Gary022
« Reply #14 on: 10 February 2013, 21:25 »
Reckon I'm just gonna modify this one to fit , just a pain in the arse really
I also had to drill and file out the holes that the turbo bolts go into because they weren't lining up properly either.
Fitting this bad boy started with excitement but now it will just be relief when it's done , I really hope there's no more problems once I get my front pipe modded and the rest goes on ok
« Last Edit: 11 February 2013, 00:27 by Gary022 »
Mk4 Golf Gti 1.8T
Offline Felton
« Reply #15 on: 11 February 2013, 00:23 »
As u said mate u mite just have a funny one mine fitted straight on with only one prob and that it knocks on the rear beam that will be sorted on mine the first lamba sits up and the second one sits face ing the drivers side mine and rios I think are arz engines that mite be why mate ?
Offline Gary022
« Reply #16 on: 11 February 2013, 00:30 »
Yeah mines aum and its also an import from Barcelona according to the log book , surely this wouldn't effect it tho.
Like I say it's just turning out to be a lot more work than first expected , it's a nightmare loosing the daily runner so all I can hope for is that it will fit together (eventually) and be worth it
Mk4 Golf Gti 1.8T
Offline Gary022
« Reply #17 on: 12 February 2013, 00:26 »
Looks like I definitely got a dud frontpipe.
Further anaylisis today showed the front nut for the first sensor to not only be out of position but also an incorrect thread to match the sensor. Due to it not fitting I've decided to renew both sensors at a cost of £120 seeing as they are both rusted and one almost threaded. This is a safer option as new sensors should work better with the new exhaust hopefully throwing up no Ecu faults.
On a positive note a second check showed the rear lambabda sensor should fit despite it being slightly tight.
So far this job has entailed , cutting and welding on a sports cat , red driling turbo bolt holes , relocation of front lambada sensor  , purchasing new sensors/nuts and extension of the centre section.
Sometimes It's just never straight forward lol , really hope this is worth the hassle  :nerd:
« Last Edit: 12 February 2013, 00:29 by Gary022 »
Mk4 Golf Gti 1.8T
Offline baxxy
« Reply #18 on: 12 February 2013, 00:32 »
Sounds like a nightmare and a dear one at that mate  :angry:
Offline Gary022
« Reply #19 on: 12 February 2013, 00:35 »
Yeah these things are sent to try us and this ones doing a pretty good job
Mk4 Golf Gti 1.8T
