Author Topic: Mk3 gti 8v HELP PLEASE wont start something weird is going on  (Read 7557 times)
Offline Kmad
Re: Mk3 gti 8v HELP PLEASE wont start something weird is going on
« Reply #20 on: 11 February 2013, 19:30 »
Is it possible that if that sensor is faulty ecu will not signal fuel pump to work??
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #21 on: 11 February 2013, 19:44 »
It tells the ECU which cylinder needs fuel and which one needs a spark,so i guess faulty Crank Sensor would not send a signal to send any fuel to the cylinders.
Offline Kmad
« Reply #22 on: 11 February 2013, 19:59 »
F@£k me i am lost now , checked every part of fuel system electronics there is and everything seems fine! Why the hell am i reading correct voltage at the pump socket but it still wont work is anoying the sh!t out off me... How is this possible??? I am starting to think that when the pump is conected and load comes on something fails in that wireing and not inough curent runs through to run the pump .... I dont know anymore....
Offline dixie180
« Reply #23 on: 11 February 2013, 20:01 »
If the Crank Sensor is f**ked your fuel pump won't get the signal from the ECU.Did you run the VAGCOM on the engine and if so what fault codes did you get up,if any.
Rob
Offline Kmad
« Reply #24 on: 11 February 2013, 20:06 »
Ok that gives me a bit of hope , tommorow frend is bringin the fault reader and we are going to hook it up... Btw when i connect multimetar to two far outer pins of the crank sensor its reading mega ohms , i dont think thats right but i dont know for shure which pins i should test...
Offline Kmad
« Reply #25 on: 11 February 2013, 20:11 »
BTW guys sorry for misspelling here and there i am originally from Croatia!
Offline dixie180
« Reply #26 on: 11 February 2013, 20:12 »
Only 2 pins will give you a reading and it should be in the range of 500 to 700 ohms. :grin: no worries bud don't like seeing folk suffering with Mk3 golf rage :laugh:Pins 1 and 3 voltage 9-14.5v.
« Last Edit: 11 February 2013, 20:22 by dixie180 »
Offline Kmad
« Reply #27 on: 11 February 2013, 20:39 »
Just tested it and its reading 7.00 mega ohms ... f**ked??
Offline dixie180
« Reply #28 on: 11 February 2013, 20:42 »
Yep absolutely  :sad:.Probably best to run the diagnostics aswell but new Crank Sensor on the shopping list i think.
Offline Kmad
« Reply #29 on: 11 February 2013, 20:44 »
Ok thanks dixie 180! Hope is back  :smiley:
