Author Topic: Fitting Coilovers.. what else do i need???  (Read 2899 times)
Judderi
Re: Fitting Coilovers.. what else do i need???
« Reply #10 on: 28 July 2005, 09:47 »
Yeah the shaft thats spinning that the bolt secures to should have some sort of allen key or nut shape to the top of it. Hold this then tighten the nut.
Offline pegasus
1.8 20VT GTI
Offline monzablue16v
« Reply #12 on: 28 July 2005, 21:23 »
Hang on a moment :)
After spending the evening swearing at my coilovers top top "retaining nut" Big 22mm nyloc thing the shaft obviously spins! but it's a nyloc nut and just sheared the 8mm flat for holding the shocker whilst trying to undo it. can I use this to undo it I thought You needed that tool for the strut mounting rubber top strut mount nut. Can I use it to undo my top 22mm nut??? or do I need to take it to the impact wrench owning garage????
I only want to change my topmounts!
Offline knobby
« Reply #13 on: 29 July 2005, 00:18 »
ok well i got them all fitted...
there knocking loads which is p1ssing me off already...
How do you recommend i set these bad boys up.. there ride height adjustable and damper adjustable.
Dave
Old VW's never die...they just go faster!
Offline Mr Blue
« Reply #14 on: 29 July 2005, 09:12 »
slam it you tart :cool:
that nocking noise is annoying. stick a large washer between the topmount and the coilover.
Offline knobby
« Reply #15 on: 29 July 2005, 09:26 »
it seems to fit really well already though.. Front end is rubbin already and it doesnt feel like a hard right.. seems boucy..
D
« Reply #16 on: 29 July 2005, 23:30 »
I just drove mine home after changing all the mounts and adding washers to the strut.
It's like riding  jetski that's the only way I can describe it bounces like a b*stard and still knocking like a b*stard too
So given up 2nd hand coilovers coming off next week and spanking new gsf boge lowered kit going on bugger really wanted coilovers too! ah well Ebay it is..
Offline Mr Blue
« Reply #17 on: 30 July 2005, 00:03 »
Going all soft are we monza :wink:
awww  :tongue:
Offline knobby
« Reply #18 on: 30 July 2005, 00:06 »
BLue... come online messenger...
Gotta sort out these coilovers next week.. ahhhh.. LOL
D
« Reply #19 on: 30 July 2005, 12:08 »
Yup I like my fillings where they are and my car is shaking itself to bits which can't be good for it!
