Author Topic: Calling 3inch eBay exhaust guys  (Read 19319 times)
Offline davemk4
Re: Calling 3inch eBay exhaust guys
« Reply #120 on: 21 August 2013, 11:48 »
Ive heard tge 3" systems and sound alot louder than milktek both louder and completly different sound imo.
Stage 2 they can map out the eml issue cant they?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Prawny
  • R-tech power!!!
« Reply #121 on: 21 August 2013, 12:05 »
that's the thing dave, Mine isn't loud, at all, it sounds very similar to my old non res miltek, and not at all intrusive. very strange.
Anyone half decent at mapping can map out the EML, it doesn't have to be done as part of a 'stage 2' or anything, you can map it out on a standard car even.
Offline davemk4
« Reply #122 on: 21 August 2013, 12:14 »
Thats goodvto know about mapping... cheers.
Offline Prawny
  • R-tech power!!!
« Reply #123 on: 21 August 2013, 12:36 »
Somewhere like R-tech or badger 5 are able to do it, I believe R-tech will even patch it into your existing map for a small fee mate.
generic st1 codes like revo and things can't do it though, only the people who actually write maps can do it for you :)
I had mine mapped out on a stock car before I even decatted it, knowing that I would do soon.
Offline davemk4
« Reply #124 on: 21 August 2013, 12:58 »
Got a generic stage 1 but dying to sort stage 2 just wonderedcif can get away with a stage 2 then fit fmic later in year..... surley it will make the power just not hold the power due to heat?
Offline Prawny
  • R-tech power!!!
« Reply #125 on: 21 August 2013, 13:33 »
no, fmic is an absolute MUST for st2. Without an intercooler, what is it? just a stage 1 with too much boost and lots of heat?
nasty nasty. With inlet temps silly high from the stock SMIC the timing could never be optimised to see it's potential anyway, as even 1 single pull would have IAT's too high for the kind of timing a st2 map would typically run.
do it once and do it right mate :)
Offline GTi_James
« Reply #126 on: 21 August 2013, 14:27 »
Spacers arn't really the solution lads, you MIGHT get away without an EML for a while, maybe even for a long time, but ultimately, if you've decatted an AUM / AUQ, you'll get a light on unless you have the threshold altered in the map.
AGu on the other hand, knock yourselves out, no lights for you boys :)
I'm surprised to hear people saying they're loud still, I push 350bhp of gas through mine and it's no louder than a non res miltek at all!
admittedly mines been in since end of may and no codes or lights etc. maybe one of the luck ones so far, may only go stage 1 on rtech as im not a power chaser but its nice to have if needed  :lipsrsealed:
what would i be looking at for a garret28 if i were to go that way? out of curiousity obviously
Offline davemk4
« Reply #127 on: 21 August 2013, 15:49 »
Thanks  :smiley:
Offline mar_k
« Reply #128 on: 22 August 2013, 11:55 »
I watched Dan turn the rear Lambda off on my mates mk4 AUM,
He just changed the setting from 1 to 0 so that it read 'OK' constantly
« Last Edit: 23 August 2013, 21:44 by mar_k »
Offline davemk4
« Reply #129 on: 22 August 2013, 15:03 »
^^^ can this be done with vag com?
