Author Topic: Complete breather hose change?  (Read 1224 times)
Offline madsb
« on: 05 February 2013, 14:02 »
Doing what the title says.
Bought these two parts (expensive! :s):
http://www.ebay.co.uk/itm/VW-GOLF-VENTO-MK3-2-0L-BREATHER-HOSE-PIPE-C711-/200602588902
http://www.ebay.co.uk/itm/VW-GOLF-VENTO-MK3-2-0L-BREATHER-HOSE-PIPE-C331-/190589339963
For some reason, they seem too short.. What am I missing? Haven't actually tried to attach them yet, but it's pretty obvious i think.
Cheers.
Offline boneybradley
  • Back in a Mk3...
Re: Complete breather hose change?
« Reply #1 on: 05 February 2013, 14:40 »
I can't see ebay at work, but from memory the breather comes in 3 pieces
I will check again at home and see what you've bought
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 05 February 2013, 14:40 »
Those are the right ones IF your engine is the 8v gti.
If its the 16v then you need dif ones.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline madsb
« Reply #3 on: 06 February 2013, 09:04 »
My car is the 8v :) but anyone know what the missing part is?
Offline itavaltalainen
« Reply #4 on: 06 February 2013, 09:35 »
those two parts plus some jubilee clips are the whole breather hose.
they go to the rocker cover and from there one end of the short tube goes through a pipe to the intake hose.
other end (of the hard plastic pipe) goes in the oil retention box. there are no other parts afaik...
part 16 was split into 2 which are the ones you bought
