The garage
tdi auto box wont go into top gear
Topic: tdi auto box wont go into top gear (Read 1492 times)
Britman
Here all the time
04 February 2013, 17:41 »
I saw a passat 1999 and was curious if anyone knew if an expensive fix? or what it is
Ben Lessani
The poor mans MK2 Haynes author
Re: tdi auto box wont go into top gear
04 February 2013, 18:58 »
Usually 5th is the first to go on a manual box when it runs low on fluid. So at a guess, the box is low on ATF. Although, I'm not sure how the planetary gears are set up on an auto and if its subject to the same weakness.
Britman
Here all the time
05 February 2013, 11:03 »
Thanks for reply. I was hoping it be quick fix like something like that but cant seam find out what maybe it a whole box prob not worth buying even if cheap. Usually most major box issues the box dont go into drive at all I thought.
Wayne
Sir Postalot
05 February 2013, 13:33 »
Start with the basics, try fresh fluid and clean the filter or get it scanned and see if it has any fault codes stored.
The garage
