Author Topic: aftermarket sunroof leak?  (Read 7233 times)
Offline dubber36
Re: aftermarket sunroof leak?
« Reply #10 on: 31 January 2013, 07:59 »
Once they start leaking, that's it, they're fecked. Most retro fitted sunroofs back in the 80's would leak after a couple of years.
Aftermarket sunroofs have got much better over the years, so you could always see if there is room to fit a slightly larger one. That way, they would cut a slightly larger hole in the roof, so it would be like starting all over again.
Offline search
« Reply #11 on: 31 January 2013, 16:50 »
iv took it all out cleaned it out, then used lots of silicone to just shut it all up fingers cross its worked. (never used a sunroof before even when i had one years ago)
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline wil892
« Reply #12 on: 31 January 2013, 19:27 »
I've got one of these aftermarket sunroofs on mine, it was leaking and raining like yours, but the previous owner had already siliconed it up. I took the glass out (very quick) using the clip, removed all the silicon, got a sponge and warm water and cleaned all the crap out of the grooves around the seal. Once dry I sprayed some silicon SPRAY, the stuff used for lubricating, on the seal.
I thoroughly cleaned the glass sealing surfaces with window cleaner and replaced the glass.
I haven't had a drop come in all the way through the winter and I can open the sunroof when I want to. As long as the seal isnt perished it should just need a good clean and lubrication with the spray.
Might work if you want to use the sunroof at the moment  :laugh:
Tornado Red Golf Mk2 GTD 1991
Offline search
« Reply #13 on: 31 January 2013, 20:34 »
Nice gives me hope. any idea what seal i should buy to fit this sun roof? i don't even no what car the sun roof came from but the seal looked to small for it.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline wil892
« Reply #14 on: 01 February 2013, 00:46 »
If the sunroof is the same as mine it is called a Britax Sunhatch, unfortunately I don't have a picture.
A place in Bristol can supply you with the seal http://www.bristolsunroofs.co.uk/
i think it was about £30 for the seal but they actually gave me this advice for sorting the current seal, good place!
Offline search
« Reply #15 on: 02 February 2013, 10:34 »
Thanks.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
