Author Topic: Is there a way to turn off the 30 second auto lock/alarm on a Mk4 GTI ?  (Read 7824 times)
Offline gtidan
Hi all,
Recently bought a Mk4 GTI 1.8 and if you dont put the key in the ignition within something like 30 seconds the alarm goes off. This is getting really annoying, is there a way to turn this off?
Thanks
Offline jasonpi
i dont think so when i had mine i would remote unlock it then if i wasnt in the car it used to relock the doors if ur in the car that long the just stick the key in the ignition
sorry i know its not much help maybe im wrong and you can
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
If you disarm the alarm then do not open a door for 30 seconds then it will rearm, If you open a door then the alarm will not rearm.  This is a feature on Cat 1 alarms, just incase you accidentally disarm it in the house or summit
Offline fackie
...which I must say, happens to me all the time mainly when you get out of the car, go to the boot, stuff your hands with crap and then try to lock it and put the keys back in your pocket. I always end up disarming it again... Thank God for that!
Oh and btw, you WILL get a FREE iPOD if you follow these instructions:
http://www.freeiPods.com/?r=19715903
Offline BOGGLE
If i leave my door open and don't put my key in the ignition then it tries to arm itself and then the alarm goes off cos the door's open.  Very annoying :angry:
Before....During.....After
Offline kniterider
  • had most, sold most and often buy more!
i think you might be able to get this feature removed within the vagcom sofware that links to your mk4 via a lead to a laptop, you can change and alter many features of the alarm and other electrical bits on the car!
Offline GazB
Sounds like your door switch is fecked :cry:
Offline topher
  • Administrator
  • fully functioning
Yes you can disable it with vag-com, you can also pretty much tailor it to your needs using various different key-press combinations. Altering your alarm in this way though completely voids the Cat1 certification, which might be a sticky point in the event of an insurance claim :undecided:
Offline Hobnob
is the factory fitted alarm on the 1.8T thatcham cat1 ??
Hobnobs......The SAS of the biscuit community
Golf 1.8 T(ARZ) - Reflex Silver - Completely Standard
Offline GazB
yes
