Author Topic: jump start? (Bath)  (Read 2362 times)
Offline Callum_K
Re: jump start? (Bath)
« Reply #10 on: 26 January 2013, 14:36 »
Got it started yet?
Offline drc12369
« Reply #11 on: 26 January 2013, 16:02 »
Nope but ive bought one of those yellow jump start rechargable boxes from halfords. It was £114.99 but the guy who scanned it didnt notice it only came up as £59.99  :laugh: ill give it a go in an hour or so when its fully charged. Here goes nothing...
Offline itavaltalainen
« Reply #12 on: 26 January 2013, 17:15 »
Not sure how good those "cheap" ones are as I've used a more pro version at the car rental place I used to work at....
Started even with the car battery being fully dead cos people forgot inside lights on for 3 days at -25 degrees  :whistle:
Offline drc12369
« Reply #13 on: 26 January 2013, 18:53 »
ITS ALIVE!! first time instant start beautiful   :smiley:
Offline Jasikasisback
« Reply #14 on: 26 January 2013, 19:02 »
if that charging unit is yellow then return it asap. the battery inside doesn't last if you rarely use it and costs more to replace than the whole unit. i hope you have abetter one!!
Offline drc12369
« Reply #15 on: 26 January 2013, 20:16 »
It aint those bright yellow cheap ones. This is a vommy yellow colour that was £115 i just got it cheap(59) it says in instructions to charge it once every 3 months. Its cheaper than adding the £80 AA homestart either way im happy. Took it out gor a run to charge it up. Should be fine. If not ill post it :laugh:
