Author Topic: A few questions on getting different headlights  (Read 3373 times)
Offline brewey
Re: A few questions on getting different headlights
« Reply #10 on: 25 January 2013, 07:01 »
If you can't find genuine anni lights fk automotive do anni style ones for about 90quid. Or you could have a go at splitting yours apart and doing the joey mod.
Fk also do a set of projector headlights without the halo/ angel eye. So it looks more like OEM r32 lights. Have a look around to see what it is you want.
2000 1.8T ARZ - OEM+
Offline Haribo!
« Reply #11 on: 25 January 2013, 07:15 »
awesome!
I've found these:
http://www.fk-shop.de/en/Lighting-Tuning/Headlight/Headlight-Set-suitable-for-VW-Golf-4-type-1J-yr-98-03-black-RHD-LHD.html
And these:
http://www.fk-shop.de/en/Lighting-Tuning/Headlight/Headlight-Set-suitable-for-VW-Golf-4-type-1J-yr-98-03-black.html
I'm not sure which ones I should be going for, What's the difference? Will they still adjust from the dash? :/ mk2's were so much simpler :D
« Last Edit: 25 January 2013, 07:19 by Haribo! »
LakerLover
« Reply #12 on: 25 January 2013, 10:55 »
Offline Haribo!
« Reply #13 on: 25 January 2013, 17:36 »
Do any non genuine vw headlights work with the adjuster from the dash?
Offline Chris#101
« Reply #14 on: 25 January 2013, 18:02 »
has anyone brought anything direct from fk automotive?
do they post to uk?
how quick was delivery time? :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline dom
  • Back in a Mk4
« Reply #15 on: 25 January 2013, 18:37 »
awesome!
I've found these:
And these:
Get the ones with projector lenses, that way if you run HIDs you won't blind everyone. They will still adjust from the dash, and I've got no idea about the bulbs they take.
LakerLover
« Reply #16 on: 25 January 2013, 20:02 »
Mine where from FK but from there ebay shop and postage was about 3 working days, they do adjust from the dash and there not plug and play, i had to wire the Halo's into the sidelight cables  :huh: And the bulbs are the same as the standard bulbs i just got the chrome turning signal bulbs instead!!!! hope that helped a bit!!
Offline Haribo!
« Reply #17 on: 25 January 2013, 20:05 »
Thanks dude. got em :D
Offline Haribo!
« Reply #18 on: 25 January 2013, 20:06 »
hey cheers for that. Halo is the same as angel eye right? If so then thats ok cause I didn't get ones with angel eyes in the end.
« Last Edit: 25 January 2013, 20:11 by Haribo! »
LakerLover
« Reply #19 on: 25 January 2013, 20:41 »
yeah sorry....... Its the same,  :smiley: I think i know what ones you went for then! at least you wont have to worry about wiring them up!!! looking forward to seeing them on dude!  :smiley:
