Author Topic: 3" ebay exhaust  (Read 16070 times)
Offline Dalo Harkin
Re: 3" ebay exhaust
« Reply #70 on: 30 January 2013, 08:45 »
2 working days delivery  :lipsrsealed:
Only issue I found with fitting is where the join is over the rear beam, it's very close to get the clamp on...... I could just about hear a little blowin but as I'm working on the car with just the front wheels on ramps it's very tight under there!!!!
So you have waited all this time and it's blowing - half a job  :grin:
Offline rio_gti
Re: 3" ebay exhaust
« Reply #71 on: 30 January 2013, 09:04 »
oiiiiiii!!!!! till i get it up on a proper ramp i cant do much... i couldnt turn my head under there it was so tight!!!! also have people been using a sealent/paste on the joins or just clamping it up??
Offline Dalo Harkin
Re: 3" ebay exhaust
« Reply #72 on: 30 January 2013, 09:37 »
he he,
If I were you I would use some kind of sealant in there, you can get one forget the name of it but it looks like Clear Silicone when you put it on and then clamp it  :wink:
Offline Granta Gti
Re: 3" ebay exhaust
« Reply #73 on: 30 January 2013, 10:21 »
Ya use some paste. I putty exhaust putty but exhaust cement or silicone will do. When do you wanna use a ramp? :wink:
Offline rio_gti
Re: 3" ebay exhaust
« Reply #74 on: 30 January 2013, 13:07 »
the same time i want the exhaust tip cut down  :wink:  :grin:
Offline GTi_James
Re: 3" ebay exhaust
« Reply #75 on: 30 January 2013, 14:44 »
anyone notice a MPG drop? mates moaning about his  :undecided:
It'll only be because he's using the throttle more to hear the exhaust :wink:
thats what i told him and hey presto, hes stopped gunning around in it and hes back up to low 30s  :rolleyes:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 3" ebay exhaust
« Reply #76 on: 30 January 2013, 16:48 »
You'll find the clamp sits very close to the rear beam, mine nearly sits on it and touches with a bit of weight in the back...
I'll be checking a nice thick bit of rubber in between to stop the rattling though lol
Offline Prawny
  • R-tech power!!!
Re: 3" ebay exhaust
« Reply #77 on: 30 January 2013, 17:56 »
I used wire around the first back box mount to lift the system up slightly. Cured the knocking nicely :)
Offline rio_gti
Re: 3" ebay exhaust
« Reply #78 on: 30 January 2013, 18:15 »
Good ideas there... We'll see when it's out and about if any modding is needed then when I come to put gunk on the joints I'll sort it then!!!
Offline jonrandom
Re: 3" ebay exhaust
« Reply #79 on: 30 January 2013, 19:03 »
Put a stand under the rear beam so half the car is up on that side..... I made my exhaust like that!  :lipsrsealed: :grin:
