Golf mk3
hardmonkeys
diameter of pipe from throttle body to charcoal filter aex 1.4
Topic: diameter of pipe from throttle body to charcoal filter aex 1.4 (Read 1210 times)
dubpirate
Here all the time
22 January 2013, 18:40 »
this pipe is nackerd seems to be sum gen vw vac hose , im going to replace it with fuel pipe try sort this out
any idea of size guys
its currently sucking itself shut and the valve is just clicking
tweed
Forum addict
Re: diameter of pipe from throttle body to charcoal filter aex 1.4
22 January 2013, 18:56 »
3mm I believe.
Untitled
by
tweedub
, on Flickr
dubpirate
Here all the time
22 January 2013, 21:53 »
will it be a vac hose or fuel pipe ?? is it just air?
thar passes through this
it sits just on the inner wing next to the timing belt cover goes from the throttle bodie to a valve that's clicking
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
22 January 2013, 22:18 »
I think it is either 3 or 3.5mm tube. It's petrol vapour, I used marine grade petrol hose (happened to lie around).
Golf mk3
hardmonkeys
