Author Topic: RNS510 Fireware  (Read 3688 times)
Offline ScottA
Re: RNS510 Fireware
« Reply #10 on: 23 January 2013, 20:15 »
Hold the setup button down for 30 secs and see if a menu comes up. It should say the HW version
Offline Ess_Three
Re: RNS510 Fireware
« Reply #11 on: 23 January 2013, 20:44 »
That will work if the hidden menu is enabled.
One thing to consider regarding the version of the RNS: if you scan an early one that's had a later Firmware installed, it may well scan as a 'C' unit...but may not be.
I have VCDS scanned a RNS that looked to be a 'C' unit, but the sticker on the case said it was an 'A' unit.
It looked to be a 'C', behaved like a 'C'...but would not take a Firmware update.
So be warned...check carefully.
It's 5 mins to remove the RNS and physically check the sticker...it may save you hours of head scratching...or worse!
..but gaining motorcycles.
Offline RedHP
Re: RNS510 Fireware
« Reply #12 on: 26 January 2013, 13:30 »
Hey Fiish/Steve,
I can't seem to respond to your PM, is your account ok?
Red
*Please ignore, I was being a doughnut  :laugh:
« Last Edit: 26 January 2013, 16:53 by RedHP »
Mk6 GiT since birth in 2010
YNWA
