Author Topic: Exhaust Question - Need Info  (Read 2590 times)
Offline itavaltalainen
Re: Exhaust Question - Need Info
« Reply #10 on: 20 January 2013, 11:55 »
gti 16v yes. not 8v  :sad:
Offline tweed
« Reply #11 on: 20 January 2013, 12:02 »
Yep 16v and vr6 are the same and the exhaust should be listed to fit both. They are both 55mm. The 8v is 50mm but has a reducer pipe after the cat. So you can fit a 16v/vr6 exhaust to a 8v
Offline MK4D4VE
« Reply #12 on: 20 January 2013, 15:24 »
Thanks for the advice guys, just need to find a cheap second hand one now if anyone knows of one going...
Golf MK4 1.8 20v GTI
Offline ttelracs
  • The Fettler
« Reply #13 on: 21 January 2013, 22:08 »
I have a cheap one going.
It's the centre pipe and performance mid box which I also cobbled together with a 16v back box.  I had to change it though as the wide didn't like the droning from the mid box.. Collect from Pinner if you want.  £30.  Have a look in the classified section as posted last night
pm me and I'll send you a larger photo.
Offline boneybradley
  • Back in a Mk3...
« Reply #14 on: 21 January 2013, 23:16 »
An 8v exhaust does fit, people like bosal sell a connector piece to fit either 8v bore or 16v/vr bore exhaust from the cat back
(it's straight through connector on the 16v but is stepped down 5mm on the 8v)
Offline tweed
« Reply #15 on: 22 January 2013, 18:02 »
Why would you put a 50mm exhaust on car that is meant to be 55mm?
A mk3 diesel exhaust will fit a vr6 but its a backwards step
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #16 on: 22 January 2013, 18:20 »
yup, cats are different. if i remember correctly 8v is a ceramic one, 16v and vr are metal carriers...
Bens donor VR6 had ceramic innards to the cat
Not no ordinary GTI....
www.mixcloud.com/kells/
