Golf mk3
hardmonkeys
slight overheat??
Topic: slight overheat?? (Read 2410 times)
gazpowells
Re: slight overheat??
Reply #10 on:
16 January 2013, 22:46 »
Just an idea but has the water got enough antifreeze in could be the water freezing and stopping it been pumped round?
Only an idea as I had this with an old van I had
javalin
Reply #11 on:
17 January 2013, 09:23 »
just above half way? I.e. 90c-100c? Thats not overheating. Engine should always run @ 90c.
Check coolant levels, check fan is working. Don't worry about it.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Wayne
Sir Postalot
Reply #12 on:
17 January 2013, 10:51 »
Before you panic on the mayo issue, it might not be the head gasket, the oil cooler could have failed.
Golf mk3
hardmonkeys
slight overheat??
