Author Topic: Boneybradley's blue Mk3 8v Anniversary!! The keeper?  (Read 135886 times)
I thought the rear set up was entirely different on an estate and those springs wouldn't fit your GTI struts?
Your right estate is completely different to a hatch.
Offline boneybradley
  • Back in a Mk3...
well I thought that but the product lists
Quote
LOWERING SPRINGS HIGH TEC FIT FOR VW GOLF 3 VARIANT SYNCRO (1HX1, 1H)
and they do fit fine onto my std (bilstein) hatch shocks.... I have asked fk and they state the spring rates are higher than the hatch spec one's
  • Back in a Mk3...
amp and sub and rear head rests fitted.... being quite a productive weekend when you consider I have had all 3 kids in the warm weather!
here's how to fit the headrests.. strip the seat covers (they simply clip onto/over the metal backing! b.t.w these were freebies from a broken GL model)
unclip the plastic guides and unscrew the head rest runners
and do the reverse to fit...you do need to cut a hole for the guides to go through the seat top but it's easy to find the correct location. Plus I didn't even need to remove the seats to fit them (I do need some black covers/headrests but the fronts are identical so they shouldn't be hard to find?)
next update hopefully will be more suspension work?? (as I'm still unsure about the springs that I have fitted!!)
Offline Len
Nice Mod that Boney!  :wink: :afro:
www.sas.org.uk
www.the-ace.org.uk
Offline F17BAD
  • Golf MTM S3 GTI TURBO
front and rear headrest are different but they skins do fit, the shafts on the fronts wont fit the rears tho properly so you will need to put the skins on to your existing rear rests
early and late GTI's also have different fabrics
 :nerd:
Its a crime all GTIs didnt come with rests int he back looks gay without them
Not no ordinary GTI....
www.mixcloud.com/kells/
  • Back in a Mk3...
well that's good to know. I did trial fit a front headrest and it seemed ok, but as I already have the rears swapping the covers makes more sense... I will try and get later black fabric too  :smiley:
Offline F17BAD
fronts wont go all way in right unless u bend the legs, thwy can get  stuck. you was lucky :smiley:
Those headrests should have been standard, they really make a difference.
« Last Edit: 07 May 2013, 10:52 by Wayne »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
I've fitted rear headrests in all three of the mk3's I've owned,  as you guys say... . They should have been standard issue.
  • Back in a Mk3...
well due to injury I've done virtually no work to it! and it's now due the m.o.t (although it checks out all round ok, apart from the decat and exhaust which now rattles badly! new baffles needed?)
the mod I have done is some hella magic colour rear lights (clear)
they were very cheap for proper hella's and apart from a small crack (which is quite discreet) they seem fine although I am unsure of whether to give them some red paint (full red's?)
oh and a local guy (who's a german car specialist) breaks audi tt's for fun....maybe it's time for some goodies (or an engine? as he seems well priced and can give me proper engine history  :undecided:)
